--- title: "Update or Insert Group" --- # Update or Insert Group > You can update a row or insert a new row into the database when a key pair combination does not exist. This eliminates the need to have a database that has every possible option considered in its original design. Because of the **insert row when not present** setting, the group will insert a new record whenever the designated ID doesn't exist. Afterwards, it will update the rows in the table that are associated with the key/value references as shown in this example. ### To update or insert a new row into the database 1. Create a **New Standard Group**. 2. Drag a group of tags into the groups **Basic OPC/Group Items** section. 3. Change one of the tags to be read-only by selecting **Read Only** from the tag's **Target Name** column. 4. Select the appropriate settings under the group's **Action** tab. 5. In the group's **Action** tab, in the **Table action** area, select the **update/select** radio button. 6. In addition, select the **key/value pairs** radio button. * For the **Column** select the database table ID column. * For the **Value** column, select the read-only tag. * Select **Insert row when not present** check box at the bottom of the **Table action** area. 7. Click **Enable** and save the project to start the group.
