--- title: "system.util.getGatewayStatus" description: "Returns a string that indicates the status of the Gateway." --- # system.util.getGatewayStatus > Returns a string that indicates the status of the Gateway. This function is used in **Python Scripting**. ## Description Returns a string that indicates the status of the Gateway. A status of RUNNING means that the Gateway is fully functional. Thrown exceptions return "ERROR" with the error message appended to the string. This function can be used to test all 7.7 and later Gateways. The function can also be used to test 7.6 (7.6.4 and later) and 7.5 (7.5.11 and later) Gateways. Attempting to test Gateways older than these versions will return errors. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.util.getGatewayStatus(gatewayAddress, connectTimeoutMillis, socketTimeoutMillis)` ### Parameters |Type|Parameter|Description| |--|--|--| |String| `gatewayAddress` | The Gateway address to ping, in the form of ADDR:PORT/main.| |Integer| `connectTimeoutMillis` | Optional. The maximum time in milliseconds to attempt to initially contact a Gateway.| |Integer| `socketTimeoutMillis` |Optional. The maximum time in milliseconds to wait for a response from a Gateway after initial connection has been established.| ### Returns **String** - A string that indicates the status of the Gateway. A status of RUNNING means that the Gateway is fully functional. ### Scope Client ## Code Examples ```python title="Example #1" def checkRemoteGateway(): status = system.util.getGatewayStatus("10.20.6.253:8088/main") if status == "RUNNING": print "Central Gateway is available!" else: print "Error: " + status # It's important to do this as an asynchronous operation, as the method # may block for some time. system.util.invokeAsynchronous(checkRemoteGateway) ```
