--- title: "system.user.getUsers" description: "Retrieves the list of users in a specific user source." --- # system.user.getUsers > Retrieves the list of users in a specific user source. This function is used in **Python Scripting**. ## Description Retrieves the list of users in a specific user source. The "User" objects that are returned contain all of the information about that user, except for the user's password. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.user.getUsers(userSource)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String | `userSource` | The name of the user source to find the users in. ### Returns **List** - A List of User objects. ### Scope Gateway, Designer, Client ## User Object You can access most of the basic user properties via a call to "get" which returns a null value if the requested item is not present. For example: `user.get("firstname")` will return that user's first name, or a null value if a name hasn't been set. The following list represents the various values you may use in this manner: - username - firstname - lastname - notes - schedule - language In addition to these properties, the user object has other methods on it to retrieve more information: - **user.getId()** - returns the internal identifier object that the backing user source needs to identify this user - **user.getRoles()** - returns a sequence of strings representing the roles that this user belongs to - **user.getContactInfo()** - returns a sequence of ContactInfo objects. Each of these objects will have a contactType and value property representing the contact information, both strings. - **user.getScheduleAdjustments()** - returns a sequence of ScheduleAdjustment objects. Each of these objects will have two date properties, "start" and "end", a boolean property, "available", and a string property called "note". - **user.getPath()** - returns a QualifiedPath object that represents this user in a deterministic manner. ## Code Examples ```python title="Example #1" # This example will print the first and last name of all users, using the default datasource: users = system.user.getUsers("") for user in users: print user.get(user.FirstName) + " " + user.get(user.LastName) ```
