--- title: "system.user.addRole" description: "Adds a role to the specified user source." --- # system.user.addRole > Adds a role to the specified user source. This function is used in **Python Scripting**. ## Description Adds a role to the specified user source. When altering the Gateway System User Source, the [Allow User Admin](gateway\gateway-settings\gateway-setup.md) setting must be enabled. ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): User Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.user.addRole(userSource, role)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `userSource` | The user source to add a role to. Blank will use the default user source. String| `role` | The role to add. Role must not be blank and must not already exist. ### Returns **UIResponse** - an object with lists of warnings, errors, and info about the success or failure of the add. ### Scope Gateway, Designer, Client ## Code Examples ```python title="Example #1" # This example adds a role "Operator" to the user source "MyUserSource". system.user.addRole("MyUserSource", "Operator") ```
