--- title: "system.opchda.replace" description: "Replaces values on the OPC-HDA server if the given item ID exists." --- # system.opchda.replace > Replaces values on the OPC-HDA server if the given item ID exists. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): OPC Server Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.opchda.replace(serverName, itemId, value, date, quality)` ### Parameters |Type|Parameter|Description| |--|--|--| |String |`serverName` |The name of the defined OPC-HDA server.| |String |`itemId` | The item ID to perform the operation on.| |Object |`value`| The value to replace.| |Object| `date` |The date to replace.| |int |`quality` | The quality to replace.| ### Returns **int** - The items quality resulting from the operation. ### Scope All
