--- title: "system.opchda.readRaw" description: "Reads raw values from the OPC-HDA server." --- # system.opchda.readRaw > Reads raw values from the OPC-HDA server. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.opchda.readRaw(serverName, itemIds, startDate, endDate, maxValues, boundingValues)` ### Parameters |Type|Parameter|Description| |--|--|--| |String| `serverName` | The name of the defined OPC-HDA server to read.| |List |`itemIds` | A list of item ids to read.| |Object| `startDate` | The starting date/time of the query.| |Object| `endDate` | The ending date/time of the query.| |int|`maxValues`| The maximum number of values to return. 0 or less means unlimited.| |Boolean| `boundingValues`| A boolean indicating whether or not the "bounding values" should be included in the result set. The bounding values provide a value exactly at the start and end dates, but may be resource-intensive to retrieve.| ### Returns **ReadResults[]** - A list of read results which is one-to-one with the item IDs passed in. The ReadResult object has a `serviceResult` quality property that indicates whether the call was successful, and is itself a list of QualifiedValues. ### Scope All
