--- title: "system.opchda.isServerAvailable" description: "Checks to see if the specified OPC-HDA server is defined, enabled, and connected." --- # system.opchda.isServerAvailable > Checks to see if the specified OPC-HDA server is defined, enabled, and connected. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.opchda.isServerAvailable()` ### Parameters |Type|Parameter|Description| |--|--|--| |String |`serverName`| The name of the OPC-HDA server to check.| ### Returns **Boolean** - Will be true if the server is available and can be queried, false if not. ### Scope All
