--- title: "system.opc.browseSimple" description: "Allows browsing of OPC servers in the runtime returning a list of tags." --- # system.opc.browseSimple > Allows browsing of OPC servers in the runtime returning a list of tags. This function is used in **Python Scripting**. ## Description Allows browsing of OPC servers in the runtime returning a list of tags. browseSimple() takes mandatory parameters, which can be null, while browse() uses keyword-style arguments. :::note The spelling on the opcServer and device parameters must be exact. ::: ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.opc.browseSimple(opcServer, device, folderPath, opcItemPath )` ### Parameters |Type|Parameter|Description| |--|--|--| |String | `opcServer`|The name of the OPC server to browse| |String| `device` | The name of the device to browse| |String|`folderPath`|Filters on a folder path. Use * as a wildcard for any number of characters and a ? for a single character.| |String | `opcItemPath` | Filters on a OPC item path. Use * as a wildcard for any number of characters and a ? for a single character.| ### Returns **OPCBrowseTag[]** - An array of OPCBrowseTag objects. OPCBrowseTag has the following functions: * getOpcServer() * getOpcItemPath() * getType() * getDisplayName() * getDisplayPath() * getDataType() ### Scope All ## Code Examples ```python title="Code Snippet" # This example will print out the the OPC item path for each item in a specific folder, # Browse Ignition's OPC-UA Server. This can be changed to match any connected OPC server. server = "Ignition OPC-UA Server" # Focus on the "SLC" device connection. This must match a valid device connection in the OPC server. device = "SLC" # Specify that the folder path should contain "B3". folderPath = "*B3*" # This example is not filtering on a specific OPCItemPath, so it pass Python's None for this parameter opcItemPath = None # Call browseSimple and store the results in a variable. Note that it may take some time to complete the browse. OpcObjects = system.opc.browseSimple(server, device, folderPath, opcItemPath) # For each returned address, print out the for address in OpcObjects: print address.getOpcItemPath() ```
