--- title: "system.gui.showNumericKeypad" description: "Displays a modal on-screen numeric keypad, allowing for arbitrary numeric entry using the mouse, or a finger on a touchscreen monitor." --- # system.gui.showNumericKeypad > Displays a modal on-screen numeric keypad, allowing for arbitrary numeric entry using the mouse, or a finger on a touchscreen monitor. This function is used in **Python Scripting**. ## Description Displays a modal on-screen numeric keypad, allowing for arbitrary numeric entry using the mouse, or a finger on a touchscreen monitor. Returns the number that the user entered. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.gui.showNumericKeypad(initialValue [, fontSize][, usePasswordMode] )` ### Parameters |Type|Parameter|Description| |--|--|--| |Number| `initialValue` |The value to start the on-screen keypad with.| |int |`fontSize` | The font size to display in the keypad. [optional]| |boolean| `usePasswordMode` | If True, display a * for each digit. [optional] | ### Returns **Number** - The value that was entered in the keypad. ### Scope Client ## Code Examples ```python title="Example #1" # This function is a holdover for backwards compatibility. Input components now know when the client is in touchscreen mode and respond accordingly. # This script would go in the MouseClicked or MousePressed action of a Text Field or Numeric Text Field. # For Integer Numeric Text Field: if system.gui.isTouchscreenModeEnabled(): event.source.intValue = system.gui.showNumericKeypad(event.source.intValue) # For Double Numeric Text Field: if system.gui.isTouchscreenModeEnabled(): event.source.doubleValue = system.gui.showNumericKeypad(event.source.doubleValue) # For Text Field: # notice the str() and int() functions used to convert the text to a number and # vice versa. # str() and int() are built-in Jython functions if system.gui.isTouchscreenModeEnabled(): event.source.text = str(system.gui.showNumericKeypad(int(event.source.text))) ```
