--- title: "system.gui.getSibling" description: "Given a component event object, looks up a sibling component." --- # system.gui.getSibling > Given a component event object, looks up a sibling component. This function is used in **Python Scripting**. ## Description Given a component event object, looks up a sibling component. Shortcut for event.source.parent.getComponent("siblingName"). If no such sibling is found, the special value None is returned. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.gui.getSibling(event, name)` ### Parameters |Type|Parameter|Description| |--|--|--| |EventObject| `event` | A component event object.| |String |`name` | The name of the sibling component.| ### Returns **PyObject** - The sibling component itself. ### Scope Client ## Code Examples ```python title="Example #1" # This example will get its sibling Text Field's text, and use it. textField = system.gui.getSibling(event, 'TextField (1)') if textField is None: system.gui.errorBox("There is no text field!") else: system.gui.messageBox("You typed: %s" % textField.text) ```
