--- title: "system.file.openFiles" description: "Shows an \"Open File\" dialog box, prompting the user to choose a file or files to open." --- # system.file.openFiles > Shows an "Open File" dialog box, prompting the user to choose a file or files to open. This function is used in **Python Scripting**. ## Description Shows an "Open File" dialog box, prompting the user to choose a file or files to open. Returns the paths to the files that the user chooses, or None if the user canceled the dialog box. An extension can optionally be passed in that sets the filetype filter to that extension. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.file.openFiles([extension], [defaultLocation])` ### Parameters | Type | Parameter | Description | |---|---|---| | String | `extension` | A file extension, like "pdf", to try to open. [optional] | | String | `defaultLocation` | A folder location, like "C:\MyFiles", to use as the starting location for the file chooser. [optional] | ### Returns **List of Strings** - The paths to the selected files, or None if canceled. ### Scope Client ## Code Examples ```python title="Example #1" # This code would prompt the user to open files of type 'gif'. If None is returned, it means the user canceled the open dialog box. paths = system.file.openFiles('gif') if paths != None: # do something with the file ``` ```python title="Example #2" # This code would prompt the user to open files of type 'pdf' from their stored documents folder. If None is returned, it means the user canceled the open dialog box. # Note: the computer running this code needs to have network access to the "fileserver" computer. path = system.file.openFiles('pdf', '\\fileserver\PDF_Storage') if path != None: # do something with the file ```
