--- title: "system.eam.queryAgentStatus" description: "Returns the current state of the matching agents." --- # system.eam.queryAgentStatus > Returns the current state of the matching agents. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.eam.queryAgentStatus(groupIds, agentIds, isConnected)` ### Parameters | Type | Parameter | Description | |---|---|---| | List | `groupIds` | A list of groups to restrict the results to. If not specified, all groups will be included. | | List | `agentIds` | A list of agent names to restrict the results to. If not specified, all agents will be allowed. | | Boolean | `isConnected` | If True, only returns agents that are currently connected. If False, only agents that are considered down will be returned, and if not specified, all agents will be returned. | ### Returns **Dataset** - A dataset with columns AgentName, NodeRole, AgentGroup, LastCommunication, IsConnected, IsRunning, RunningState, RunningStateInt, LicenseKey, and Version, where each row is a new agent. :::note Possible values for RunningState and RunningStateInt are: 0 = Disconnected, 1 = Running, 2 = Warned, 3 = Errored ::: ### Scope All ## Code Examples ```python title="Example #1" # This script will loop through each row of the dataset and grab out every value from that row and assign it to a matching variable. Those variables can then be used in some way. results=system.eam.queryAgentStatus() for row in range(results.rowCount): agentName=results.getValueAt(row, "AgentName") nodeRole=results.getValueAt(row, "NodeRole") agentGroup=results.getValueAt(row, "AgentGroup") lastComm=results.getValueAt(row, "LastCommunication") isConnected=results.getValueAt(row, "IsConnected") isRunning=results.getValueAt(row, "IsRunning") runningState=results.getValueAt(row, "RunningState") runningStateInt=results.getValueAt(row, "RunningStateInt") licenseKey=results.getValueAt(row, "LicenseKey") platformVersion=results.getValueAt(row, "Version") # Can include some code here to use the variables in some way for each row like printing each variable to the console. ``` ```python title="Example #2" # This script will grab status information from agents called Agent1, Agent2, Agent3, and will then place the data into a table on the same window. results=system.eam.queryAgentStatus(agentIds=["Agent1", "Agent2", "Agent3"]) event.source.parent.getComponent('Table').data = results ```
