--- title: "system.dnp3.freezeAnalogs" description: "Issues a freeze command on the given analog outputs." --- # system.dnp3.freezeAnalogs > Issues a freeze command on the given analog outputs. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](projects/project-properties/project-properties.md#client---permissions): DNP3 Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.dnp3.freezeAnalogs(deviceName, [indexes])` ### Parameters | Type | Parameter | Description | |---|---|---| | String | `deviceName` | The name of the DNP3 device driver. | | List | `indexes` | A list of specific indexes on which to issue the freeze command. An empty list can be passed to freeze all analogs. | ### Returns Nothing ### Scope All ## Code Examples ```python title="Example #1" # This example shows a request to freeze all analog inputs in the outstation. system.dnp3.freezeAnalogs("Dnp3", []) ``` ```python title="Example #2" # This example shows a request to freeze analog inputs at indexes 1, 3, and 5. system.dnp3.freezeAnalogs("Dnp3", [1, 3, 5]) ```
