--- title: "system.dataset.toDataSet" description: "This function is used to 1. Convert PyDataSets to DataSets 2. Create new datasets from raw Python lists. When creating a new dataset, headers should have unique names." --- # system.dataset.toDataSet > This function is used to 1. Convert PyDataSets to DataSets 2. Create new datasets from raw Python lists. When creating a new dataset, headers should have unique names. This function is used in **Python Scripting**. ## Description This function is used to 1. Convert PyDataSets to DataSets 2. Create new datasets from raw Python lists. When creating a new dataset, headers should have unique names. ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax (Without Headers) `system.dataset.toDataSet(dataset)` ### Parameters Type | Parameter | Description ------- | ------- | ------ PyDataSet | `dataset` | A PyDataSet object to convert. ### Returns **Dataset** - The newly created dataset. ### Scope All ## Syntax (With Headers) `system.dataset.toDataSet(headers, data)` ### Parameters Type | Parameter | Description ------- | ------- | ------ PySequence | `headers` | A PyDataSet object to convert. PySequence | `data` | A list of rows for the new dataset. Each row must have the same length as the headers list, and each value in a column must be the same type. ### Returns **Dataset** - The newly created dataset. ### Scope All ## Code Examples ```python title="Example 1" # This example create a single column dataset. header = ['myColumn'] rows = [[1], [2]] dataset = system.dataset.toDataSet(header, rows) ``` ```python title="Example 2" # This first example shows how this function can be used to convert from a PyDataSet (which is what system.db.runQuery returns) to a normal DataSet, which is the datatype of a Table component's data property. pyDataSet = system.db.runQuery("SELECT * FROM example1 LIMIT 100") table = event.source.parent.getComponent("Table") normalDataSet = system.dataset.toDataSet(pyDataSet) table.data = normalDataSet ```
