--- title: "system.dataset.filterColumns" description: "Takes a dataset and returns a view of the dataset containing only the columns found within the given list of columns." --- # system.dataset.filterColumns > Takes a dataset and returns a view of the dataset containing only the columns found within the given list of columns. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.dataset.filterColumns(dataset, columns)` ### Parameters Type | Parameter | Description ------- | ------- | ------ Dataset | `dataset` | The starting dataset. PySequence | `columns` | A list of columns to keep in the returned dataset. The columns may be in integer index form (starting at 0), or the name of the columns as Strings. ### Returns **Dataset** - A new dataset containing the filtered columns. ### Scope All ## Code Examples ```python title="Example 1" # This example takes the dataset from a five column Bar Chart and displays a subset of the data in two separate tables. This is performed in a button component actionPerformed script. chartData = event.source.parent.getComponent('Bar Chart').data northSouth = [1, 2] # North Area, South Area cols eastWest = ["East Area", "West Area"] filteredData = system.dataset.filterColumns(chartData, northSouth) event.source.parent.getComponent('NorthSouthTable').data = filteredData filteredData = system.dataset.filterColumns(chartData, eastWest) event.source.parent.getComponent('EastWestTable').data = filteredData ```
