--- title: "system.dataset.exportCSV" description: "Exports the contents of a dataset as a CSV file, prompting the user to save the file to disk." --- # system.dataset.exportCSV > Exports the contents of a dataset as a CSV file, prompting the user to save the file to disk. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](projects\project-properties\project-properties.md#client---permissions) restrictions. ## Syntax `system.dataset.exportCSV(filename, showHeaders, dataset)` ### Parameters Type | Parameter | Description ------- | ------- | ------- String | `filename` | A suggested filename to save as. Boolean | `showHeaders` | If true (1), the CSV file will include a header row. Dataset | `dataset` | The dataset to export. ### Returns **String** - The path to the saved file, or None if the action was canceled by the user. ### Scope Client ## Code Examples ```python title="Example 1" #This snippet would prompt the user to save the data currently displayed in a Table component to a CSV file, and would open the file (in an external program, presumably Excel) after a successful save. table = event.source.parent.getComponent("Table") filePath = system.dataset.exportCSV("data.csv", 1, table.data) if filePath != None: system.net.openURL("file:///"+filePath.replace('\\','/')) ```
