--- title: "system.alarm.unshelve" description: "Unshelves alarms in accordance with the path parameter." --- # system.alarm.unshelve > Unshelves alarms in accordance with the path parameter. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](projects\project-properties\project-properties.md#client---permissions): Alarm Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.alarm.unshelve(path)` ### Parameters Type | Parameter | Description ------- | ------- | ------- String[] `path` | A list of possible source paths to search at. If a path ends in "/*", the results will include anything below that path. ### Returns Nothing ### Scope All ## Code Examples There are no code examples for this function.
