--- title: "Report Component - Line Shape" description: "The Line shape component can be used to display a straight line any where in a report." --- # Report Component - Line Shape > The Line shape component can be used to display a straight line any where in a report. ![](lineShape.png) **Component Palette Icon:** ![](lineIcon.png) ## Description The Line shape component can be used to display a straight line any where in a report. It can run north-south, east-west, or diagonally. Select the Line shape on the Report Component Palette to make it active, and click and drag to draw a Line any where in your Report Designer. Hold shift while dragging to force the angle of the line to a 45 or 90 degree angle. You can change the stroke style, color, width, pattern, and more. ## Properties ![](lineProps.png) | Property | Description | Category | |--- |--- |--- | | Fill | If true, the shape will fill its space with color. | Stroke and Fill | | Fill Color | If true is selected, the color that will fill the shape. | Stroke and Fill | | Opacity | How opaque the fill color is, between 0 and 1. | Stroke and Fill | | Stroke Style | What style of stroke or border to use: Hidden, Shape Outline, Border, or Double. To learn more about stroke styles, refer to [Stroke and Fill Properties](reporting/report-design/stroke-and-fill-properties-for-reports/stroke-and-fill-properties-for-reports.md). | Stroke and Fill | | Stroke | [Details for the chosen stroke.](reporting/report-design/stroke-and-fill-properties-for-reports/stroke-and-fill-properties-for-reports.md) Each Stroke has its own properties depending on the Stroke Style chosen. | Stroke and Fill | | Roll | Number of degrees this shape is rotated clockwise. | Basic Properties | | Scale X | Amount to scale the width of this shape. 1 is scale to 100%. | Basic Properties | | Scale Y | Amount to scale the height of this shape. 1 is scale to 100%. | Basic Properties | | Visible | If true, the shape will be visible. | Basic Properties | | X | Horizontal distance in pixels between the left edge of this shape and the left edge of the page. | Basic Properties | | Y | Vertical distance in pixels between the upper edge of this shape and the top edge of the page. | Basic Properties | | Stroke Color | Color of the line. | Line Properties | | Stroke Width | Width of the stroke in pixels. | Line Properties | ## Example - Two Lines ![](lineExample.png) | Property | Value | |--- |--- | | Stroke Style | Border | | Stroke Color | Amber | | Border Bottom | True | | Border Top | True | | Stroke Width | 5 pixels |
