--- title: "Gantt Chart" description: "A Gantt chart is used for task scheduling. It shows a list of named tasks, each of which have a start date, an end date, and a percentage complete. This allows an easy way to visualize tasks, workflows, and scheduling." --- # Gantt Chart > A Gantt chart is used for task scheduling. It shows a list of named tasks, each of which have a start date, an end date, and a percentage complete. This allows an easy way to visualize tasks, workflows, and scheduling. ![A chart titled "Gantt Chart" with a Tasks category axis listing First Task, Second Task, and Third Task, and a Date axis spanning March 20 through March 26. Each task is drawn as a horizontal bar positioned between its start and end dates, with an inner bar showing how much of the task is complete.](gantt0.png) **Component Palette Icon:** ![Gantt Chart component palette icon](gantt1.png) ## Description The Gantt chart is configured by populating its Data property. Each row of the dataset represents a task. There should be four columns: the task label, the start date, the end date, and the percentage (0-100) complete. ## Properties | Name | Description | Property Type | Scripting | Category | |--- |--- |--- |--- |--- | | Antialias | Draw with antialias on? Makes text smoother. | boolean | .antialias | Appearance | | Axis Font | The font for axis labels. | Font | .axisLabelFont | Appearance | | Border | The border surrounding this component. NOTE that the border is unaffected by rotation. | Border | .border | Common | | Chart Title | An optional title that will appear at the top of the chart. | String | .title | Appearance | | Complete Color | The color to draw the amount completed in. | Color | .completeColor | Appearance | | Cursor | The mouse cursor to use when hovering over this component. | int | .cursorCode | Common | | Data | The data driving the chart. | Dataset | .data | Data | | Data Quality | The data quality code for any tag bindings on this component. | int | .dataQuality | Data | | Date Axis Title | A date label to display on the axis title. | String | .dateAxisTitle | Appearance | | Incomplete Color | The color to draw the amount remaining to do in. | Color | .incompleteColor | Appearance | | Mouseover Text | The text that is displayed in the tooltip which pops up on mouseover of this component. | String | .toolTipText | Common | | Name | The name of this component. | String | .name | Common | | Plot Background | The background color for the plot. | Color | .plotBackground | Appearance | | Task Axis Title | A task label to display on the Axis Title. | String | .taskAxisTitle | Appearance | | Task Color | The main color to draw tasks. | Color | .taskColor | Appearance | | Tick Font | The font for tick labels. | Font | .axisTickLabelFont | Appearance | | Title Font | The font for the optional chart title. | Font | .titleFont | Appearance | | Tooltips? | Show tooltips on tasks? | boolean | .tooltips | Behavior | | Visible | If disabled, the component will be hidden. | boolean | .visible | Common | ## Scripting ### Scripting Functions This component does not have scripting functions associated with it. ### Extension Functions This component does not have extension functions associated with it. ### Event Handlers Event handlers allow you to run a script based off specific triggers. See the full list of available event handlers on the [Component Events](scripting\scripting-in-ignition\component-and-window-scripting\component-events.md) page ## Customizers This component does not have any custom properties.
