--- title: "Roster Management" description: "The user management panel provides a built-in way to edit rosters from a client." --- # Roster Management > The user management panel provides a built-in way to edit rosters from a client. ![](../imgs/roster.png) **Component Palette Icon**: ![](../imgs/roster1.png) ## Description ## Properties | Name | Description | Property Type | Scripting | Category | | ------------ | -------------------------------------------------------------------------------------- | ------------- | ------------- | ---------- | | Antialias | Draw with antialias on? Makes text smoother. | boolean | .Antialias | Appearance | | Border | The border surrounding this component. NOTE that the border is unaffected by rotation. | Border | .Border | Common | | Data Quality | The data quality code for any tag bindings on this component. | int | .Data Quality | Data | | Enabled | If disabled, a component cannot be used. | boolean | .Enabled | Common | | Name | The name of this component. | String | .Name | Common | | Styles | Contains the component's styles. | Dataset | .Styles | Appearance | | User Source | The user source to manage users in. If blank, uses the project's default user source. | String | .User Source | Behavior | | Visible | If disabled, the component will be hidden. | boolean | .Visible | Common | ## Scripting See the [Roster Management Scripting Functions](roster-management-scripting-functions.md) page for the full list of scripting functions available for this component. ### Event Handlers Event handlers allow you to run a script based off specific triggers. See the full list of available event handlers on the [Component Events](scripting\scripting-in-ignition\component-and-window-scripting\component-events.md) page. ## Customizers + [Vision Component Customizers](visualization-and-dashboards\understanding-components\component-customizers\component-customizers.md)
